How to disable small properties pop-up (on hover)?
Simple question - When you hover over an entity, say MTEXT or a DIMENSION, a small properties dialog pops up near the cursor, e.g. Color, Layer, Text Height for an MTEXT entity. When I want to see and adjust properties, I greatly prefer just selecting an entity and modifying the settings in the properties pane. The little pop-up dialog near the cursor constantly gets in my way ... I don't might the 'brighten up' highlight on hover, but that dialog is not desired in my case...
Thanks
Brian
  • Please see RollOverTips and Quad in Settings dialog ... also, both is available as statusbar options buttons (RT, Quad), disabling those should help.
    many greetings !
  • Thanks, Torsten ... I'll give these a try
