Mechanical workflow
I'm new in bricscad mechanical, but i have experience in Sketchup and Solidworks.
Is there a document in which I can understand the mechanical workflow?
I have a lot of question that I post here, to start quickly. The purpose is to eavaluate the product and replace the Solidworks license.
  • How to rename components.
  • How to import geometry from outside a component, into it.
  • How to cut a beam such HEB in 45° degrees.
  • How to handle layers.
  • Hi mecdep,
    There are several guides and tutorials on the Bricsys webpage to help you understand the best mechanical workflow, which you can find here: https://help.bricsys.com/hc/en-us/categories/360000417593-BricsCAD-Mechanical
    For your questions:
    • To rename a component you should save the file with the new name and use the command BMREPLACE on the relevant component to exchange it for the new component.
    • I am not entirely sure what you mean by your second question, do you want to create a multi-body part? Could you provide some more info?
    • This depends on the nature of the beam. If you place a beam from our standard part library (Components panel) you will have to use the command BMDISSOLVE first to convert it to a solid body. Then you can use the direct modeling tools such as slice, extrude or rotate to create a 45° cut.
    • To learn about the layers I suggest you take a look at this post from the Bricsys blog: https://blog.bricsys.com/bricscad-journey-layers-linetypes/
    For any other questions you might have it can be useful to take a look at our Help center: https://help.bricsys.com/hc/en-us
    I hope this helps!
    -Fredrik
