Mouse Zoom very slow Version 20.2.06
Hy Guys I updated BricsCAD to the Version 20.2.06 and since the update the mouse zoom acts very slow. I already tried to set the Zoomfactor higher and the resolution lower but it didn`t work out.
Is there someone with a similar problem?
I did not notice a slowdown on 20.2.06 on Linux.
Since you already checked ZOOMFACTOR and VIEWRES, the remaining culprit might be AntiAliasScreen - see the warning in the settings dialog. -
AntiAliasScreen didn`t make a change and there is no warning in the settings dialog.
But thanks for your answer. -
I was referring to the attached help text at the bottom of the settings window.
Did you check if the problem is independent of particular drawings and visual styles? -
I also tried different visual styles and different drawings but it
s not solving the problem at all. I also looked a second time because of the antialiasscreen it
s turned off so thats also not the Problem.
Thanks for your answer. -
does this allso happen when you open an empty file with default settings?
I have noticed this problem when using a high resolution mouse, in particular my Logitech MX Master 3 is very slow when zooming compared to other mouse models/types
Howdy, Stranger!
