Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Strangeness - Using Text Override with angle dimension
Hi all,
I don't know what I'm missing, but I've noticed that if you try to use the Text Override option with an angular dimension, the dimension text just disappears. The reason I like to override the text is because it drives me nuts when the dimension displays 45°". I just want 45°.
Text Override works fine with other dimensions just fine.
What's the trick?
-B
Best Answer
Answers
  • Hmmm...
    While looking at this more closely, the DIMSTYLE settings appear to be global settings. So, if I clear the field for the " inch symbol from the Dim Suffix field, it clears it for all dimensions; not just the angular dimensions.
    And, creating a new Dimstyle just for the few times I'm using angular dimensions doesn't seem very efficient.
    If the text override entry causes the angle text to disappear, that's still a bug in the software.
    For now, the better workaround for me is adding my angular dimension, selecting the dimension, and then clearing the " inch symbol from the Dim Suffix just for that dimension. All other dimensions maintain the correct suffix.
  • Roy's advice is right, better to set your DIMSTYLE up correctly rather than use overrides. In this case I suggest that you investigate creating a Child Style. This will allow you to specify how you want your angular dimensions to look.
    Regards,
    Jason Bourhill
    BricsCAD V20 Ultimate
    CAD Concepts
    1030 x 739 - 89K
  • I would suggest looking at the DIMLUNITS of the dimtyle first.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
