How to properly paste code?
Here is what I get when pasting a c# function, its a nightmere.
What am I doing wrong?
I use the "code" button which adds the ''and lets me paste between the 's.
Brace yourself (with curly's if needed...):
`public static bool ImportBlkFromDwg(string fullpath) {
bool ret = false;
Document doc = AcAp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
if (File.Exists(fullpath)) {
//was Database tmpDb = new Database(true, true);
Database tmpDb = new Database(false, true);
try {
tmpDb.ReadDwgFile(fullpath, FileShare.Read, true, ""); //bcad catches here
using (var docLoc = doc.LockDocument()) { string bName = Path.GetFileNameWithoutExtension(fullpath);
if ACAD
db.Insert(bName, tmpDb, true);
endif
if BCAD
db.Insert(bName, bName, tmpDb, true); //this is critical bName, bName, for bcad
endif
} ret = true; } catch (System.Exception ex){ Debug.Print(ex.Message); } finally { tmpDb.Dispose(); } } return ret; }`
It's the Forum, it strips out some special characters , or treats them as MarkDown formatting options. In your case, it is treating # at the start of a line as a heading.
Not ideal, but for code it is best to attach it to your post as a text file.
Regards,
Jason Bourhill
BricsCAD V20 Ultimate
CAD Concepts -
hmm, notice how it treated the first half of code as just text, down to "tmpDb.ReadDwgFile(fullpath, FileShare.Read, true, ""); //bcad catches here"?
Its not just the character switch, but other things that butcher the code.
This really needs to be improved, code is fundamental to BCAD health and momentum. -
It would be could if they adopted a form of Markdown suited to coding, such as GitHub Flavored Markdown.
https://github.github.com/gfm/Regards,
Jason Bourhill
CAD Concepts -
There is another way that works better:
- Paste the code in your post. In case of a code block make sure to leave blank line(s) above and below the code.
- Select the pasted code.
- Choose: Format > Code.
- If the code does not contain line ends, the code will be formatted as inline code: `abc`, else the code will be formatted as a code block: 4 spaces will be added to the start of each line.
ok
public static bool ImportBlkFromDwg(string fullpath) { bool ret = false; Document doc = AcAp.DocumentManager.MdiActiveDocument; Database db = doc.Database; if (File.Exists(fullpath)) { //was Database tmpDb = new Database(true, true); Database tmpDb = new Database(false, true); try { tmpDb.ReadDwgFile(fullpath, FileShare.Read, true, ""); using (var docLoc = doc.LockDocument()) { string bName = Path.GetFileNameWithoutExtension(fullpath); #if ACAD db.Insert(bName, tmpDb, true); #endif #if BCAD db.Insert(bName, bName, tmpDb, true); //this is critical bName, bName, for bcad #endif } ret = true; } catch (System.Exception ex){ Debug.Print(ex.Message); } finally { tmpDb.Dispose(); } } return ret; }
lets see. ahh, success!
I think linux makes you smarter @Roy Klein Gebbinck , that is not fair.
Howdy, Stranger!
