tin surface editing tools - can't find tin editing tools in civil tab
aridzv
edited November 2020 in 3D Modeling
Hi,
after watching this video from bricscad support team,
i was looking for some tools shown in this video (see attached photo),
tools like "Assign image to tin" and "Project to TIN", and more.
where can i find them?
thanks,
Ari.
  • I'm using bricscad V21 Pro *
  • I thought those only worked in platinum version, or whatever is above pro. I had the same issue a while back.
    thx
  • In v20 the site tools required Platinum, in v21 the Pro version has them.
  • @Terry Dotson
    Holy cow, they listened to me (and others). Thanks for mentioning!
    I need to get with them on their roadmap for civil tools. I started the same process 15 years ago so can offer suggestions on what to hit first.
    In particular, external data for alignments and surfaces so sharing is easy...
  • The obvious is read CIV3D alignments they are there now as proxy objects.
    thx
    Hi James.
    after some "digging" i found that those command are actually exist in V21 PRO,but only if you type them manually.
    one more strange thing is,
    that Although those commands can't be found anywhere in the customize tab,
    when i crated a new tools for those commands, the images for those commands exists...
    make a long story short:
    those commands exist in V21PRO,
    and the easy way for me was to create tools for them and append those tools to the CIVIL Tab in the ribbon.
