Adding areas does not add right
betazero
edited December 2020 in 2D Drafting
Adding works fine nm...lol
  • I don't think we can help unless you include more information. I assume this is a table, but you don't really say. You don't provide any information on how the calculations are done other than to say that there is an n/144 division used, but adding does not generally include division factors. All data in the table is expressed as square feet so no conversion from square inches would be required. This looks to me like your algorythm is including the 1st Floor A/C when it should not. I'm not sure that is a Bricscad issue.
  • That has to be a unit's setting. Maybe post the dwg.
  • Ok this was operator error....ugh...
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
