Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Cannot Click on anywhere on V20.11.2 Mac OS BIG
Hello,
I hope all is well. I am having an issues with my Version 20 Bricscad on my Mac with Big Sur installed. I am working on a drawing and all of a sudden I cannot click on any thing within BricsCad. I am working in Modeling mode and if I try to click on any of the buttons within the ribbon there is no response. In my command bar I get a message “ opposite side” when I try to click on anything.
Is this a glitch? Is it something that I am clicking and doing that is causing this? Is there a command prompt that I can type and it take me back and allow me click and select? I have tried undo using the command Z but that does not work either.
I also updated to V20.2.11 from V20.2.10. I just want to understand if if this might be a glitch or if I am doing something that is causing this.
Thx
  • Are you only on Big Sur with Intel Mac
    (I haven't seen that behavior so far)
    or on Big Sur with a new M1 machine,
    so Bricscad via Rosetta ?
  • Yes I am only of Big Sur with an Intel Mac.
  • In my command bar I get a message “ opposite side” when I try to click on anything.
    Sounds a bit like you are still in an active command that waits for another special input.
    I think I ran into that also when I tried new tools.
    Does it work again after you clicked ESC a few times ?
  • Does it work again after you clicked ESC a few times ?
    Hello Michael, Yes I have tried to ESC multiple times. The weird thing is that when this happens, I cannot click on anything including anywhere in the ribbon.
  • Hello Everyone,
    Here is another screen shot of what is happening on a drawing that I am working on. All of a sudden I cannot click on anything within the ribbon and toolbar. It seems as if I go into a particular setting and I cannot get out of it. Everywhere that click I get that command box to select the faces, At the same time I get opposite corner on the command box anywhere that I click.
    Any Ideas? Thanks in Advance.
    1920 x 1080 - 796K
  • Öh, never seen that myself.
    And I can't really understand the messages in your Command Line.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
