show polygon area while drafting it ?.
Hello,
I am starting a land subdivision and, being new to Bricscad, wondered if it's possible to dynamically show the area of a closed polyline as I move one side of it? Is there a setting in Bricscad or a LISP routine available to show this? Similar to how the line tool shows the length and angle while it's being drawn.
thanks
alexsunny
  • Anthony Apostolaros
    edited February 2021
    Just keep the Properties panel open while you adjust it.
  • If you were to consider third party software, the parameter labels in DotSoft's MapWorks react to grip editing and change instantly. In this example, a grip edit was made to the center vertex (of 4 polylines) and all labels change immediately after picking the new point.
  • Changing area of a poly can be done simply using fields no need for other software.
  • Fields only update on REGEN (or other commands), not when the linked geometry is being modified. AA's PROPs suggestion is the best answer using the stock product.
