Working with tables, how to force a comma to show up for numbers
Coming from AutoCAD I could create a table in a drawing and input numbers into it. If the number was anything greater than 999 then AutoCAD would automatically add the necessary comma at the thousands or millions place. I have searched high and low in all of the help forums and cannot figure out how to force this behavior in table in BricsCad
  • This is a Autocad solution not sure how in BRICSCAD I am sure can get at it program wise just need to find the correct variable in Table definition
  • I had a deeper look and found this but there must be though a over riding top level setting. It will be part of the table dictionary, I just looked at a table. It is feasible to update all the cells via a lisp.
    (vla-getcellformat Obj 2 0)
    "%lu2%th44" is the thousands format for a cell
    Command: (vla-getText Obj 2 2)
    "456,789.123"
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
