DXF question (imports form Qgis)
Hi ,
I am a big fan of QGIS!
This amazing piece of opensource software can be of used for may geo-tasks and civil engineering
What is a bit wierd about QGIS is that it's exports to DXF are not so optimal with colors and pline width.
There is a file in Qgis called header.dxf which decribes the the export parts
Does any have an clue how objects with true colors 0,0,0 is assigned and stored in DXF format?
I want to change this into white or red as default..
nb
The same file has be modified that to 'meters' in stead of insunits 6
  • The INSUNITS can be changed in the header file. But not the color of entities. But it should be possible to create a Lisp for that.
  • Thanks Roy. I was hoping i could have a fix directly for Qgis.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
