existing and new situation of a buildingplan
Hi folks, I'm new to BricsCad, how do you deal with the existing and new situation of a building plan within BricsCad.
I have now created the existing state with BIM and am wondering how I can best work with the new situation.
Make a copy in a new drawing and adjust it?
thank you very much for your responses.
gr. Frank
Hi Frankv,
I would suggest to try using Drawing Customization (https://help.bricsys.com/hc/en-us/articles/360017588360-Create-drawing-types-with-Drawing-Customization) on both the existing and new plans. Your new elements can carry a specific value in a property, ie. Description and your input could be New. This means in your Drawing Customization, your rule to set is "Description (BIM) = New".
You can do something similar to your Existing elements which are about to be demolished or removed, so they won't show in your new plans.
Thanks.
Kin
See also this revived thread:
https://forum.bricsys.com/discussion/35631/existing-new-demolish-in-bim
Howdy, Stranger!
