SAVEALL: Save all open files
The SAVEALL command doesn't do what I was hoping, to save all open files in BricsCAD at the same time, to avoid tabbing between them and save each individually. Is there another command that will do this?
  • Saveall should save all open files, regardless of whether there were changes made to that file or not. At least that is how it works on my end. I do have some add-ons installed so loading those add-ons when opening a file could cause something in the drawing to be considered as changed which might cause the saveall to work, but even without that it works as far I can tell.
    What happens if you right click on a tab and select saveall?
    Are you on Windows, Mac or Linux? It could be that there is a platform specific bug that you are running into.
