Extrude a rect also did a subtract - how to prevent it?
I extruded a rectangle (yellow) and the extrusion passed through an existing solid (green).
What I thought I would get is an interference pattern as a visual clue but the action did a subtract on the existing solid. All 4 pieces of the angle iron base were identical before the extrusion. Now two have cuts in their vertical sides.
I checked the EXTRUDE docs and saw no reference (that I understood) to change the behavior to not subtract, but to interfere. Is there a setting?
Welcome!
It looks like you're new here. Sign in or register to get started.
  • You need to set DMEXTRUDEMODE and PUSHPULLSUBTRACT to your liking.
    I guess the most intuitive setting for the former is 6, and 0 for the latter: This will allow you to DMEXTRUDE boundaries that lie on a solid's face to create holes or protrusions, without having to fear that you might alter other solids encountered on the way, and the same would apply if you DMPUSHPULL recognized boundaries.
  • Thank you. I'll look those setting up.
  • edited January 2022
    FYI...
    I did not find those two variables by searching in Settings. In version 22, Mechanical workspace, I did find DMPUSHPULLSUBTRACT works to prevent the subtraction. Set it to disabled.
  • Hi all,
    For PUSHPULL you indeed have a setting to prevent subtracting by setting DMPUSHPULLSUBTRACT to 0. For EXTRUDE, all options are shown in the commandline during the command. You can also use the Hotkey-assistant (indicated in red in the image) to switch between the options with the Ctrl-key. To not subtract from existing solid, use option Create.
    More info: https://help.bricsys.com/document?title=_guides/BCAD_3D_modeling/GD_creatingsolidsusingtheEXTRUDEcommand.html&documentVersion=V22
    Kind regards,
    Chi-Yan
Welcome!
Welcome!
