Unable to Save File
Hi,
I'm a new user of BricsCAD. I'm trying to save a file, however I keep getting an error as follows:
"ERROR: Failed to save the file.
Object of class AcDbDictionaryVar can't be cast to AcDbAttributeDefinition.
The file may be in use or has the read-only attribute set".
I have ensured that the file is not in use anywhere else, and that it does not have 'Read-Only' checked off in Windows Explorer File Properties.
I thought I should check in with you guys as I don't have the first clue of where to start.
  • Is the file by any chance located on a Network Shared Drive?
    Try locally. If that works then set your drive to the trusted windows zone.
    (Internet properties > Security: local Intranet > Sites > Advanced)
    here add file://ipaddress-of-your-shared-folder
  • Roy Klein Gebbinck
    edited November 2018
    Maybe using the _Audit command can fix things. The first part of the message seems to indicate an issue with the dwg itself.
  • I tried moving it to my C:/ drive and I also tried using the Audit command. The issue still persists.
    Thank you regardless.
  • Does SaveAs work?
    Can you share the drawing (or a slimmed down version of it, where the issue still exists)?
  • Did you change your location to save? or you can check the hidden file in this folder. I think it could be worked
  • I have the same issue.
    The original DWG was in the network. I got this error, audit and local saveas didnt work.
    It's not the first time this happened to me.
    The DWG was made in Autocad.
    I am using Bricscad 2020.
  • Same problem here. My boss had that same issue in a different file. Can't save. Did somebody find out a fix for it?
  • I found a way! That's what I did and totally worked for me.
    - SaveAs the file in the most recent type "AutoCAD 2018 (*.dwg)"
    - Close BricsCAD
    - Open a new drawing
    - Go to File > Drawing Utilities > Recover > select the file you have created by SaveAs
    - Done!
  • Often Windows thinks a closed file is still open, e.g. refuses to rename it, until reboot.
  • Same problem here and cannot save.
    Did anybody found a solution for this problem?
  • This is saved in MS OneDrive ...
    Maybe it doesn't like the "é" in the Path ?
    (or is the Path already too long ?)
