Problem with Radical Purge addon and PDF Underlay
Hi.
When using the "Radical Purge" add-on when all the options are selected (see Capture.PNG screenshot),
When I Uncheck the "PDF Underlay" I don't get that error.
Does anyone have any idea what the problem is?...
Thanks,
Ari.
Thanks,
Ari.
If you do a bit of research you should be able to find a contact for Gilles Chanteau. He is on lots pf forums and is very helpful.
Google radical Purge this will take you to appstore then a link onto his page where there is CONTACT
Howdy, Stranger!
