is it possible to load a specipic workspace (.CUI file) on startup?
Hi.
when I open bricscad it load with the last workspace I used (Modeling for example).
Is there a way to make bricscad to load a specific workspace (Drafting for example) regardless of what was the last used workspace?
thanks,
aridzv.
  • Maybe (command "workspace" "s" "Drafting") in your load on startup lisp, I have a custom one so this would be like last line. There are defualt startup lisps for Bricscad or Acad etc.
    thanks.
    the selection should be C instand of S - see updated command - (command "workspace" "C" "Drafting").
    it worked.
    thanks again,
    aridzv.
  • Good to hear working did not test very far.
