How to flatten 2D entities in Z direction in BricsCAD Lite?
Hello,
How to flatten 2D entities in XY (TOP VIEW), in BricsCAD. Because I have tried the SUPERFLATTEN Lisp available on the internet which is not working.
If any workaround to flatten 2D entities in BricsCAD Lite.
Kindly Guide.
Regards
Aaditya Patil
Kindly Guide.
Regards
Aaditya Patil
0
Have you tried the built-in Flatten command?0
Hello Roy,
Yes, I Have tried It, But it only works on some entities.
can you please give me a workaround if is there any, drawing having more than 100 thousand entities.
0 -
Which ones does it not work on - inside Blocks/Xrefs? I think they have to be individually opened and flattened.0
Hello Tom,
I have exploded all the blocks and then I have used the SUPERFLATTEN Lisp command. It doesn't work properly on some Polylines, Lines, Arcs, etc. 2D entities.
I have observed that SUPERFLATTEN has some limitation to flattening 2D Entities which exceeds from given limit in lisp.
Kindly guide me on how to resolve this issue.
0
