Convert an extension version
I'm trying to install MeteorSpec LT for BricsCAD 2.2.6 (created for BricsCAD 23) in BricsCAD 25, how can I change the app Bricscad version?
In AutoCAD only was needed to edit a file and change version like 2022 fin name and replace with 2024, how can I do this in Bricscad?
  • Why did you not ask the authors of Meteorspec ?
    Ps what is Meteorspec.
  • The MeteorSpec LT works in BricsCAD V21-V24. The last test was in V24.2.06(x64). All supported versions can be found on the website https://meteorspec.com
    The MeteorSpec LT is freeware plugin for BricsCAD for electrical engineers and designers. The plugin is designed for analysis and design of 0.4 kV distribution networks. With MeteorSpec-NETWORK you can:
    create 0.4kV distribution network models of any level of complexity; perform calculations of short-circuit currents according to IEC60909; perform calculations of voltage losses in low-voltage feeders with a balanced load and calculations of power sum and actual load currents; quickly obtain the cable specifications of network models and more.
    MeteorSpec-ELECTRIC is collection of various calculators for electrical designers.
  • Hello.
    From the producer page, it seems that version 2.2.6. was tested in Bricscad V23-V25.
    https://meteorspec.com/features/whats-new
    So, the installation should be similar in all these versions.
  • I lost my hope, after 100 attempts Inever receive answer from BricsCAD or AutoCAD, never.
