Hello.
From the producer page, it seems that version 2.2.6. was tested in Bricscad V23-V25.
https://meteorspec.com/features/whats-new
So, the installation should be similar in all these versions.
Convert an extension version
I'm trying to install MeteorSpec LT for BricsCAD 2.2.6 (created for BricsCAD 23) in BricsCAD 25, how can I change the app Bricscad version?
In AutoCAD only was needed to edit a file and change version like 2022 fin name and replace with 2024, how can I do this in Bricscad?
Why did you not ask the authors of Meteorspec ?
Ps what is Meteorspec.
1 -
The MeteorSpec LT works in BricsCAD V21-V24. The last test was in V24.2.06(x64). All supported versions can be found on the website https://meteorspec.com
The MeteorSpec LT is freeware plugin for BricsCAD for electrical engineers and designers. The plugin is designed for analysis and design of 0.4 kV distribution networks. With MeteorSpec-NETWORK you can:
create 0.4kV distribution network models of any level of complexity; perform calculations of short-circuit currents according to IEC60909; perform calculations of voltage losses in low-voltage feeders with a balanced load and calculations of power sum and actual load currents; quickly obtain the cable specifications of network models and more.
MeteorSpec-ELECTRIC is collection of various calculators for electrical designers.1 -
Hello.
1 -
cool
0 -
I lost my hope, after 100 attempts Inever receive answer from BricsCAD or AutoCAD, never.
0
