Questions before moving to BricsCAD
PMVAR
edited April 2025 in Moving from A-CAD
Hello,
we ae in the process of deciding if we should move from AutoDesk to BricsCAD and I've been testing for the last few weeks. Mostly for our purposes I would say that the changeover is almost one to one, there are however a few points that impact productitivity/comfort that I would like to check.
a) Fillet: Autodesk offers the opportunity to see the fillet before the command is ended which can then be easily changed if it is not correct. As far as I can see in BricsCAD I have to complete the command and if it is incorrect undo and then restart the fillet command. Is there a way in BricsCAD to preview the fillet? Some option that I may have missed?
b) The second issue relates to counting blocks. I've read numerous posts and tested numerous Lisps regarding this however have not been able to solve my issue.
We have a number of blocks with various visibility states. AutoDesk offers the countblocks command in which I can count the blocs based on the visibility state. This works quite well and is heavily used by us.
I have found a lisp (from Lee-Mac) that will count the blocks for me and place the results in a table however where AutoDesk can change the block names based on their visibility states BricsCAD will adjust the block name to a irrelavant / ranomised(?) name e.g. *U83.
I have attached two files that will hopefully show this a bit clearer.
I would be interested to get your opinions on this. Thanks in advance.
