Adding Blocks to Pallet
in Autocad you can drag and drop blocks in the pallet for easy use, I tried this with bricscad and it doesn't seem to work (I'm using Microvellum BSB, so it's version 25).
any insight?
@bstanley, This was recorded in V26, but it should be the same in V25. Activating
the dialog that gives you the option to add to the palette is a right mouse on the item you want to include in the palette. I have no idea what Microvellum BSB is, but this is how it works in ordinary Bricscad.
0 -
- Open the tool palette you would like to add your block to
- In the command line, type XB (EXPBLOCKS)
- Find the block you would like to add
- Right click and select "Add to Current Toolpalette"
Now you should be able to easily drag and drop your block from the tool palette!
0 -
thanks for the help. For those wondering. Microvellum BSB is Micorvellum software built on BricsCAD and currenlty using V25.
0 -
Oh cabinet maker. I wrote a replacement for Pattern Systems’ DrawPower back in the day lol.
0
