Adding Blocks to Pallet
in Autocad you can drag and drop blocks in the pallet for easy use, I tried this with bricscad and it doesn't seem to work (I'm using Microvellum BSB, so it's version 25).
any insight?
  • @bstanley, This was recorded in V26, but it should be the same in V25. Activating
    the dialog that gives you the option to add to the palette is a right mouse on the item you want to include in the palette. I have no idea what Microvellum BSB is, but this is how it works in ordinary Bricscad.
    1. Open the tool palette you would like to add your block to
    2. In the command line, type XB (EXPBLOCKS)
    3. Find the block you would like to add
    4. Right click and select "Add to Current Toolpalette"
    Now you should be able to easily drag and drop your block from the tool palette!
  • thanks for the help. For those wondering. Microvellum BSB is Micorvellum software built on BricsCAD and currenlty using V25.
  • Oh cabinet maker. I wrote a replacement for Pattern Systems’ DrawPower back in the day lol.
