Dynamic block resetting in drawing
When i add a dynamic block to drawing from the tool palette and there are current blocks the drawing the existing blocks change , some resize some stretch or rotate and i have to go find all instances of blocks to make sure they are correct. This does not occur with all my dynamic blocks and not seem to follow a pattern i can see, sometimes i add a block and it's ok.
Any suggestions would be welcome, thanks
sorry for got to add the image
0 -
Could you please specify which BricsCAD version do you use?
0 -
This was with latest version 26.2.03, i've since uninstalled it and gone back to previous version. Was causing me too much time trying to fix my drawings and too many errors in my dynamic blocks even the simple dynamic blocks were not working right.
0 -
I wasn't able to reproduce this with my example. It would be very useful if you'll create a support request about observed problems with dynamic blocks. It seems nobody yet reported similar issue with toolpalettes.
0 -
A question… are you using arrays of these items in your drawing? If yes then V26 has a bug that is somehow related to having arrays in combination with xref parametric components/mechanical blocks, maybe this could be a contributing factor but it was quite difficult to replicate from scratch on the computers of BricsCAD support though eventually they managed to replicate the behaviour.
0
