Parametric Stretch command not working on 3D entities
When I use the parametricstretch command on the operations tab of the BricsCAD ribbon on a 3d block and try to animate the parameter the entire solid moves, could I be using the command wrongly or is it not suited for 3D entites, and if the latter is the case why is the icon of the command tagged 3D? Thank you.
