Window/opening in 2 walls?
Hi,
sometimes I need to create a load-bearing wall and it´s insulation separately as two walls. How can I create a opening in them? The opening is created only in one of them by default.
Thanks.
  • zoomer
    edited 10:31AM
    It was said there is an option to assign the opening to multiple Walls - which is great.
    But I did not find how/where so far.
    I am also a big fan of separating Structural vs Finishes, like it is built in reality.
    To avoid exponential increase of needed Compositions/Wall and Slab Styles.
    In FreeCAD I can do that quite easily by selecting and adding more Walls inside the Window's host Wall data field.
  • zoomer
    edited 10:22AM
    Hmmh, ….
    Bricscad AI Assist may not really understand my prompt ….
  • Hmmh,
    I am not able to copy your text
    into the prompt window.
    AFAIR I am not able to do any simple Copy/Paste of Text or Numbers into any (or most) Bricscad input fields.
  • zoomer
    edited 10:43AM
    Seems to work somehow …. if you …. select both Walls before you select and add a Window from the Library.
    It does not seem to really work with the advanced Windows (?), it cuts through both Walls but the Window seems to revert to a standard Window (?)
  • Hello.
    You could experiment with using the BMLINK command.
    https://help.bricsys.com/en-us/document/command-reference/b/bmlink-command?version=V26&id=165079057581
    First, you should thaw the BC_SUBTRACT layer, to make sure the cutting solids of the window intersect both walls.
    If this is not the case, the window might need to be reinserted.
    Depending on the case, the block definition might need to be edited to adjust the size of the cutting solids.
    After ensuring the cutting solids intersect both walls, use BMLINK and select the window.
    Further, follow the command prompt.
    You need to make sure both walls are selected as target solids.
    Eventually, BC_SUBTRACT could be frozen back.
  • JanBeno
    edited 2:31PM
    Great, it works!
    Thank you :)
