Minimalist block manager?
https://github.com/CEXT-Dan/BrxBlockMan
  • select a drawing from the directory control
  • double click or drag a block from the List control to the current drawing
  • double click the main preview to insert the whole drawing
  • click the open folder button to add your favorite folder(s)
  • use the dropdown to navigate to a favorite folder
  • right click on a dwg to open it in Bricscad
  • right click on a folder to add it to favorites
  • right click on the dropdown ctrl to clear favorites
  • Its_Alive
    edited September 27
    edited
  • 1.1.013
    • sorts the blocks by name, the control accepts keys, I.e. type S to navigate to blocks starting with S
    • right click on a .dwg to open the drawing in BricsCAD
