Why does this parametric block break when I copy it?
I can insert the block just fine, but as soon as I copy it, the rotate parametric operation completely breaks.
  • I don't use blocks like dynamic blocks, but do you not need to add coincident constraints to keep everything together?
  • Thanks for the suggestion, but it didn't help. Something with the scale operation is breaking it.
