SECTIONPLANE - SECTIONPLANESETTINGS -SECTIONPLANETOBLOCK is there a better way?
Hello,
To create sections of my 3d objects I start with SECTIONPLANE, and place my plane where I want it. Then I use SECTIONPLANESETTINGS to make my sections look the way I need it. I finish by calling SECTIONPLANETOBLCK to finally create the section.
Is there a better way to get sections or at least to make the SECTIONPLANESETTINGS to stick? Am I doing something wrong?
I tried by setting up my SECTIONPLANESETTINGS in the template file but it did not have any effect.
Thanks.
  • Hello, the section plane settings are saved within the entities of a drawing. If you copy the section plane entities into another drawing, its settings will be automatically transferred.
    There is no way to separately export just the section plane settings from a drawing to another.
  • OK, then I am going to create the plane, modify it as I like it, then make it a block and bring it every time I need it. That is better. Thanks.
