3D creation in Bricscad?
Message to Bricscad developers (as I am presently on a v23 Perpetual license i.e. no direct access to Support):
Any plans to impliment 3D model creation from 'vibe' prompts including actual 3D-concept (spatial and dimensional) language - similar to
or Claude's similar link for Blender?
I've been trying to get
to do that but while it's brilliant at creating background and surrounding landscape and topography, weather etc it fails dismally at adding say 'a bay window on the balcony' in its 2D-pic output. Almost every building-detail still has to be created in the 3D model that is uploaded to ArchRender - no shortcut (yet - but they say they're working on it) to trying out 3D features without having to model them.
Attached is sample ArchRender output, based on a Bricscad 3D mass-model uploaded which includes most of the architectural detail shown. Note, this is far more complex to prompt/describe architecturally than the typical cuboid apartment block with optimised rectangular room-layout, that the new-BIM startups usually illustrate.
If Claude could indeed do the trick of 3D model creation from prompts, including iterative correction/refinement without going back to a complete fresh run at every new prompt, then ArchRender could nicely handle the rest.
Naturally I'd love this to be possible with a Bricscad dwg-solids model.
Anyone? Lyubov Osina for Bricscad?
0 -
Hi @Tom Foster , I'm not aware about such plans. A note for @jaghanivasan , I suppose.
0 -
Thanks. Who is @jaghanivasan ?
0 -
https://www.linkedin.com/in/jaghanivasan/
0 -
Impressing result, Tom, and yes, BricsCAD urgently needs an MCP bridge, given the fact that Bricsys promoted the product with its AI-capabilities, and now all the half-baken clones already have one .
But I wonder if we are not driving the last nail into the coffin of our profession, if we let agents create the content instead of only visualizing it… but it will surely happen anyway.
0 -
Thank'ee kindly. Moving on apace - as well as ArchRender, there's similar Visoid but with rigorous versions-tree from which a new attempt can be branched, rather than starting every prompt afresh, also Plamo really apparently creates 3D Brep from a description, exports to dwg, and GPT Astra via MCP, to do 3D model creation the non-consumer-packaged way. Every CAD co shd be scrambling to keep up!
I am greatly reassured - who but a skilled architect can even imagine what result to prompt for? - plenty of work there, refining same. Maybe it'll be the routine utilitarian box-drawers, rather than the real creatives, who will find that any client can just do it for themselves.0 -
Looks a bit 2D only though.
For ETP (Effluent Treatment Plant) General Arrangement layouts) only ?
0 -
@zoomer Yes the latter one is just for ETP layouts because these are fairly standardized facilities.
Regarding the former MCP, based on the description it looks like it is 2D only as there is no mention of any 3D functionality. Though it may be useful to automate some general tasks with regard to layers etc. Otoh, using a good LLM like Claude or ChatGPT may achieve the same result and create either LISP code or BRX addon if it is for a specific repetitive task. That way you don't have to use the MCP all the time but use a command instead.
0 -
More in general, I know someone who uses AI to create 3D concepts. Even though it may look nice/good enough for a non-CAD user I can always spot multiple oddities right way so far. It will get better over time but I wouldn't let AI create 3D models for production/construction for the near future. Chances are that you will have to do so much cleaning up that it might be better to start from scratch anyway in combination with a (self-/custom-made) parametric library.
0 -
Apparently ODA is working or already has a MCP server for CAD, their Open IFC Viewer and Open STEP viewer and it looks like it is not just 2D but also 3D. Perhaps this may also work together with BricsCAD?
The e-mail text is below for those interested in this.
Regarding the MCP server for CAD their e-mail said the following:
MCP Servers webinar November 18
At DevConnect’26 you will see how to open your DWG, STEP and IFC models to the AI agent you already use, watch it work on real files, and ask the developers your questions directly.
Register at:
The session will cover:
- Two ways to use it: a stand-alone server that processes whole folders of files, or AI inside your own application, working on the model your user has open
- What the agent can do on real files: edit a DWG drawing, dimension a STEP part with PMI, lay out furniture in an IFC building
- How to try it today in Open IFC Viewer and Open STEP Viewer, where the agent works on the open model and follows your markups
- How the MCP server and its format toolsets are built: the base for working with ODA formats and for adding support for your own formats
- What comes next: DGN, Revit and Navisworks
Global session
With Sergey Vishnevetsky, Director of Development
November 18
12:00 UTC+01:00Nov 23 – Dec 4
Personal Meetings
Live Main Session
Online Q&A
Recording available
on YouTube🇺🇸 The session in USA will be held on November 19,
find out more🇨🇳 The session in Chinese will be held on November 24,
find out more0 -
There’s no reason those MCP servers need to be 2D, it’s only limited to the ActiveX API. Creating the tools is the easy part, you can have AI write its own tools. The hard part is integrating into the host application, I.e. using the command infrastructure. My guess is the harness will need to be run inside CAD’s process space and event driven, OnIdle, CommandEnded
For my Python project, I’ve (AI) created tools to where AI can load and run scripts, run unit tests, edit the code, compile and run again in a loop. It’s not practical for drawing though.
It’s going to cost you!! One round trip of my test runner uses ~3 million input tokens. For something like CAD, sending MBs of IFC or some serialized DWG format just isn’t going to work as an everyday thing. Especially for 3d where you probably need an Astra or Fable level model.
0 -
Also there should be already enough OSS Apps that read and write DWG and have an MCP. At the end you can open the DWG in BricsCAD again. Likely will not work with all that proprietary BIM and maybe Mechanical stuff, inside a proprietary DWG format. But who knows.
And I think some AI can just use the App's interface, as they read all documentation and viewed all tutorials, to produce geometry and data as needed. (E.g. in Blender)
Currently masses of hobbyists vibe code Apps by cloning popular or the Apps they are used to. It is very seldom that someone really tries to build a better App (E.g. Kugelblitz) or an (BIM) App from scratch (E.g. Lapin)
Those who skip such Apps ask for MCP to vibe CAD/BIM/….I wonder how long it will take until your AI of choice will ask if it is ok to skip using the App or MCP and instead offers to create the desired data of the end result directly and more efficiently. Like for BIM intend a final IFC file or for Mechanical a machining file. Or finally skip that altogether and make an offer for the complete building, including permits and financing, built by a friendly humanoid robot army (?)
0 -
Who will then need drawings/models anyway? All intent hence instructons to the robot army will be held non-graphically. Except, how will capitalism stage-manage all this? Will the entity offering the building be entirely a non-human DAC (Digital Automated Corporation) trading with other DACS, or will the usual human 1% 'own' these almost-DACs (i.e. DAC in all but human ownership), hence 'own' the profits, dividends and stock inflation? If so, will they want to see drawings, to approve, or will they not care, just trust their DAC?
0 -
Here’s a proof of concept of an AI harness in Python using OpenAI toolset
Samplebasically, tools are just functions with documentation, here are my test prompts
- Check what is currently in the drawing, then draw a circle of radius 25 at (50, 50) and a line from (0,0) to (50,50).
- Create a 3D cylinder base with radius 40 and height 10 resting on Z=0 at (0, 0), then stack a narrower cylinder of radius 15 and height 50 centered right on top of it.
You could probably make a tool that allows the model to make it’s own tools.
0 -
That worked really well! I separated out the tools from the main logic. You can use AI to build your tools specific to your genre
- Using existing tools, try to create a simple floor plan using lines and polylines
0 -
This is pretty cool, I added tools for layer, arc and dimension. I had asked my local model to make a 3d log cabin using cylinder. It could make the wall and roof, but it kinda got lost lol. This prompt was:
- create 2d elevations of a modern kitchen with raised panel doors and top crown molding.
A frontier model should be able to make some pretty cool stuff, and also improve the tools. I added a commented field where you can connect with your own API key. I may add a tool to where it can run it's own created python modules. what would also be helpful is a tool to where it can take a screenshot so it can use the vision tool.
Sorry for spamming the thread lol.0 -
@its_alive Re Floor plan the code was done back in the 90's sets a X and Y offset then enter room sizes, note in image shows a difference in right side so architect would need to adjust one room. Step 2 is make stud walls and out side walls other code.
0 -
The floor plan was just a quick test; I had only created line and polyline tools. I added
- get_drawing_info
- create_layer
- create_circle
- create_line
- create_polyline
- create_arc
- create_dimension
- create_text
- create_cylinder
- create_cuboid
It’s just a proof of concept, one possible method to create an AI toolset. Kind of a novelty parlor trick at the moment.
0 -
This is a test of my new create_cuboid tool, create a pyramid, in the style of Minecraft, use different color layers for the block materials, make it grand
0 -
we’re a creating 3d a wooden framed house, three rooms, use the create_cuboid to create 2x4s for the frames. Frame out the base, walls, roof trusses, and window openings..
Not bad! Qwen does not like my 3d rotation, the roof is a bit wonky lol!
0 -
I fixed the rotation issue,
0 -
Live action - brilliant. I've heard from Qonic - can now do all of this, allegedly
0 -
While goofing around with tools this morning, I quickly realized giving an LLM 500 tools (draw_line, fillet_edge, hatch_area, insert_toilet) isn’t going to work. The tools are going to need to be genre specific abstractions. Cabinet makers might have create_raised_panel_door, while some other user might want create_wall_segment. Everyone is going to want their own tools.
IMHO, if Bricsys goes down this path, build a really awesome harness with replaceable toolsets, with some sort of entity tagging protocol.
0 -
To draw this involves multiple lisps the package around 130 lisp options, so you would need as you suggest 130 different coding's. Some would use a sub library function already defined, like in a window show timber frame would call the draw 3d rectang solids or a moulding. Many years ago was asked in a demonstration to zoom in on a window, the prospective customer asked "Where is the timber moulding" our answer was how many of your construction plans show that now ? How deep a detail do you need is relevant to how far the programming of intricate details go.
Roof not shown in image.
Just a comment I dont think you need to show frame details like studs etc as here in Australia the majority of houses are built from prefab frames in either timber or steel. Are they used where you are ? Those not prefab are built hopefully by a Builder who knows the buildng code. Yes may need details when a custom frame is called for. Similar for exposed beams.
0
