v27 text editing bug / and the temp FIX
When editing an annotative text entity, with the texted variable at 0 or 2. the text becomes huge.
I have been using the 1 value to bypass.
An additional issue is converting text to mtext, again an annotative text object becomes quite large even though its is listed at the correct text height
Here is a video link to the issue
https://www.dropbox.com/scl/fi/z6b85a4x4lk26c942m765/Recording-2026-11-02-070611.mp4?rlkey=1urcblqqn0haiqirw8zlb74ns&dl=0
I delved further into the issue / bug:
Subject: V27: in-place editor for annotative text opens oversized by the annotation scale factorVersion: BricsCAD V27, Windows 11, Imperial units
Steps:- In a new empty drawing, set
ANNOSCALEto 1:8. - Create annotative text (for example “HELLO”).
- Double-click it, or run
TEXTEDIT.
Expected: The editor shows the text at its on-screen size.
Actual: The editor and selection highlight open about 8× too large. The same steps at 1:1 are normal, and non-annotative text at 1:8 is also normal.
Notes: The result is the same atTEXTED= 0 and 2.Workarounds until Bricsys fixes it:
- Set
ANNOSCALEto 1:1 while you edit annotative text, then set it back. - Edit the text through the Properties palette’s Contents field instead of double-clicking.
- Use non-annotative text where that’s acceptable.
0 - In a new empty drawing, set
Here is a utility that temporarily fixes the issue until Bricscad can fix the bug
0 -
I can reproduce zooming of annotative text during editing, but it still fully visible on the screen.
Did you report this via support request already? Please do it, so the issue could be investigated and forwarded to developers for correction.0 -
I am happy with my fix. I submitted a bug 8 months ago. a simple issue with leader scaling and it still hasn't been addressed.
0
