bribscad for linux opensuse 11
Hi allFinally i try bricscad in linux envAll workes well except cyrillic letters :(nothing workes with cyrillic lettersI also try to run russian V8 trough wine 1.1.0 it works but I have some troubles with cyrillic letters too....
  • i found that /opt/bricscad/icadit is simply the shell script... (i think that it is binary)So i found some good stuff for me :)
    # use Latin-1 charmapLANG=`echo $LANG | sed 's/\..*/\.ISO-8859-1/'`export LANG
    i will try to change this...
  • i change icad.shISO-8859-1 to ISO-8859-5so i have my text right :) But names of folders still have unreadable
  • I change one more thingi just comment all this LANG sheet... and bricscad start work perfect :) everywhere in v6 linux version...I have utf8
  • What version have you tested?
    I've tested V6 trial for couple of hours on Linux 2.6.25.18-0.2-default #1 SMP x86_64  opensuse 11
    Everything seemed OK, except autolisp interpreter. The sequence of prompts and data input seems different from AutoCad.
    I didn't test encoding anyway.
    Much desired feature is ability to connect drawing entities to external database as in "ASE" or "dbconnect" command in AutoCad.
