Get Normal Vector on Surface
Hello,
I tried to get the normal vector at specified a point on the surface of a solid, but did't found a solution yet. Is there an easy way to get it?
Thanks
  • For a flat face of a 3D solid this can be done by aligning the UCS to the face and then drawing a line from the point in the pos. Z direction. I don't know how this can be accomplished if the face is curved.
  • Thank you.
    But I need it for a curved surface.
  • I'm thinking make a Point on your Surface then make a copy of the Surface and the point then scale the copy and the point times 1.5 around its centroid. Finally make a line between the Points. ! ?  Havent tried it yet but could work. just dont know how to find the centroid. Maybe someone knows
  • What kind of Surfaces do you mean?
    If there are "oldfashioned" meshes like RULESURFs, REVSURFs or EDGESURFs  so I have an idea, how to get the Normal vector.
    Regards
    Jochen
    www.ant-ares.de
