Increase the detail of collada export
The default collada export is not detail enough, how to increase the polycon in collada export?
Looks as if you stumbled over a small inconsistency here:
the mesh density should probably be ruled by FACETRES if ddUseFacetRES/spaUseFacetRES is on, but (at least on my 17.2.10 linux version) it is not - instead the ACIS modeler properties (in the settings window) seem to control export resolution.0 -
the mesh density should probably be ruled by FACETRES if ddUseFacetRES/spaUseFacetRES is on, but (at least on my 17.2.10 linux version) it is not - instead the ACIS modeler properties (in the settings window) seem to control export resolution.Do you mean Program options -> Modeler -> Modeler settings?
Which settings control the export resolution?0 -
Another thing,
DAE from Bricsys for me brings only (unnamed, unsorted) Objects into 3D Apps.(When doing from VW I get everything nicely grouped by Layer (and Classes),
Materials, Names, Cameras, Lights...)And vice versa,
3D Apps often have mixed Z to Y axis and Bricscad lacks an automatic or an
option to correct the Up Axis. So you model may end up rotated to its side.0 -
No matter how I tweak the setting the export resolution looks same. How to adjust the polygon count of Collada export?
@Roy Klein Gebbinck said:
This may help:
https://forum.bricsys.com/discussion/24343/how-to-increase-resolution-of-stl-exportI use your setting and the polygon is higher now. Thanks a lot!
