Increase the detail of collada export
The default collada export is not detail enough, how to increase the polycon in collada export?
  • Looks as if you stumbled over a small inconsistency here:
    the mesh density should probably be ruled by FACETRES if ddUseFacetRES/spaUseFacetRES is on, but (at least on my 17.2.10 linux version) it is not - instead the ACIS modeler properties (in the settings window) seem to control export resolution.
    Do you mean Program options -> Modeler -> Modeler settings?
    Which settings control the export resolution?
  • Another thing,
    DAE from Bricsys for me brings only (unnamed, unsorted) Objects into 3D Apps.
    (When doing from VW I get everything nicely grouped by Layer (and Classes),
    Materials, Names, Cameras, Lights...)
    And vice versa,
    3D Apps often have mixed Z to Y axis and Bricscad lacks an automatic or an
    option to correct the Up Axis. So you model may end up rotated to its side.
  • No matter how I tweak the setting the export resolution looks same. How to adjust the polygon count of Collada export?
  • I use your setting and the polygon is higher now. Thanks a lot!
