Setup/Setting to Lock UCS Icon at Origin
The on_start. lisp file is used here at startup (as the renamed startup file originally used with a competing software). What would a line of code look like that would lock the UCS Icon at the 2D view origin?
In
settingssearch forucsiconand find two bitsum values:1for show icon and2for originSo if you want to have a UCS icon always shown and if possible at the origin, you want value
1 + 2 = 3.You'll also find
ucsiconposfor left, right positions and other valuable settings.In its most basic form, the following line should do:
(setvar 'ucsicon 3)You may want to consider creating
on_doc_load.lspand put it there. Location in search path and best not in "program files" locations in order to survive an update of BricsCAD.0 -
Wiebe,
This is exactly the information I needed.Thank you!
Clint Hill0
