Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Can I use Visual Studio 2010 to debug .net programs with bcad v15?
I am seeing some odd issues that do not happen with the same code using autocad 2015.
I set a breakpoint in my c# code for a modal dialog callback, like button1_clicked... and it acts like its not there.
Breakpoints outside the form code work fine, but the ones in the form code like form_load and others are not honored.
The code in the form does run though, I can do messagebox.show("did something") and they all trigger, so i know the code is running.
Just thinking maybe I need VS2012 or something, as you are supposed to use that with 2015, but I get around by referencing the 2014 assemblies for the moment...
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
