Can I use Visual Studio 2010 to debug .net programs with bcad v15?
I am seeing some odd issues that do not happen with the same code using autocad 2015.
I set a breakpoint in my c# code for a modal dialog callback, like button1_clicked... and it acts like its not there.
Breakpoints outside the form code work fine, but the ones in the form code like form_load and others are not honored.
The code in the form does run though, I can do messagebox.show("did something") and they all trigger, so i know the code is running.
Just thinking maybe I need VS2012 or something, as you are supposed to use that with 2015, but I get around by referencing the 2014 assemblies for the moment...
