big size plot not available
I cannot for the like of me figure out what is wrong with the format of the printer showed in BricsCAD. Coming from AutoCAD were I had all the options like Iso A1,A0, etc. here I have none.
I finally managed to import the plot settings from autocad user data base but that is a short term solution. What is the real problem?
iso.jpg 358.4K
  • The available paper sizes depend on the selected printer. All installed printer drivers are available in the Printer/Plotter configuration list.
    And indeed I have the proper installed printer. The thing is that if I install AutoCAD I will have all the big plot options available but in BricsCAD I don't have them. I can only create a custom paper size layout.
  • FlorianGh
    edited September 2017
    Look at the following screenshots :
    1 settings of the ploter default
    Settings of the ploter imported from AutoCAD :
  • it has been fixed. The paper standard were not checked in control panel.
    Where do you set the paper standard?
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
