big size plot not available
I cannot for the like of me figure out what is wrong with the format of the printer showed in BricsCAD. Coming from AutoCAD were I had all the options like Iso A1,A0, etc. here I have none.
I finally managed to import the plot settings from autocad user data base but that is a short term solution. What is the real problem?
The available paper sizes depend on the selected printer. All installed printer drivers are available in the Printer/Plotter configuration list.
@Louis Verdonck said:
The available paper sizes depend on the selected printer. All installed printer drivers are available in the Printer/Plotter configuration list.And indeed I have the proper installed printer. The thing is that if I install AutoCAD I will have all the big plot options available but in BricsCAD I don't have them. I can only create a custom paper size layout.
Look at the following screenshots :
1 settings of the ploter default
Settings of the ploter imported from AutoCAD : -
it has been fixed. The paper standard were not checked in control panel.
@FlorianGh said:
it has been fixed. The paper standard were not checked in control panel.Where do you set the paper standard?
Howdy, Stranger!
