Graphics not sharp - jagged diagonal lines
My Graphics card is an NVIDIA Quadro P1000. Intel COre i7 w/16GB 64bit WIndows 11 pro0
Try to increase a value of the ANTIALIASSCREEN variable (default value is 1, that means no anti-aliasing). Perform REGEN after that to see the difference.0
Same problem.
just got new laptop,
Graphics card is an NVIDIA 4060.
my previous laptop with just the integrated Inetl Iris® Xe the diagonal lines where sharp.
ANTIALIASSCREEN variable set to 5, still jagged…
dose anyone know how to fix this?
thanks,
aridzv.
0 -
Make sure the program is set to use the NVidia Card not the normal Intel graphics. Its part of windows not Cad, its in display, right click windows screen.
Other is what resolution are you running 1920x1080, I ran dual screens but second screen is an older monitor so its res is less and a bit jaggy also a 24" v's a 15"
0 -
Done that in graphic display.
also use external monitor 24" - the same I used with my old laptop.
the monitor resolution is 1920x1080 and as I wrote - it worked good with my old laptop.
I'm using the laptop HDMI port that with my new laptop is connected directly to the nvidia graphic card so I can't check if the CPU integrated graphic will give better resaults for that issue.
are their other settings I need to check,maybe with the invidia control panel settings?
0 -
do you have the nvidia control panel?
0 -
0
