Setting the layer properties in a paper space viewport
Each of my layout tabs have just one viewport.
I'd like to set up each of those viewports with a custom set of layer properties, so that no matter what layers I have turned on or off in model space, the layout tabs and the viewports on them will always have the layer properties I want them to have.
For instance, the main floor plan would not have the layers visible that would only pertain to the reflected ceiling plan and vice-versa.
I've watched several YouTube videos and also tried to follow the instructions in the BricsCAD help system here:
Based on those videos and the BricsCAD help topic, I think I have a pretty good understanding on how this should work, unfortunately though it is not working like that for me.
As a new user of BricsCAD and being a CAD novice, I'm confident the issue is with me, but I just can't figure out what I may be doing wrong.
I double-click inside of the viewport and then set the layers just the way I want them. I double-click outside of the viewport and everything looks great. However, as soon as I go back to work in model space and make any changes to the layers there, when I go back to the paperspace layout tab the visible layers are all messed up.
I'm looking for a way to permanently set the visibility of the layers in those viewports, so that no matter what the visibility status is on the layers in model space, the viewports always show the layers I want.
Any help would be appreciated.
You may need a Lisp or a script that runs the vplayer command. Say freeze all layers except one then thaw all the layers you want.
It is pretty easy to make a layer list to say a text file that is read with the names of the layers you want thawed.
Have you looked at using vplayer in a lisp ?
This will take all layers and dump to a file.
(defun dumplayers ( / layers lay fo fname)
(setq Layers (vla-get-layers (vla-get-activedocument (vlax-get-Acad-Object))))
(setq fo (open "d:\acadtemp\VPlayers.txt" "w"))
(vlax-for lay layers
(write-line (vlax-get lay 'name) fo)
(close fo)
(princ "\nAll done")
(dumplayers)0 -
Hello @DIY_Guy ,
You said:"I double-click inside of the viewport and then set the layers just the way I want them." Do you use VP overrides or common properties? You need to use columns named like VP Freeze, VP Color, etc. to set viewport overrides. If these columns are not displayed, press right mouse button on any column header and choose which properties you want to display.
0 -
Oh —- so that's what those VP columns are for
0 -
Yes ) A bit more information about that VP properties you can find in this article:
0
