Dark mode Menu and Title bar
Could you elaborate a bit?
0 -
I hooked into the menubar and forced it to draw darkmode via Win32 calls. All of the menus throughout BricsCAD draw dark. I may have spoken too soon though, the right click menu for stuff like OSNAPs is wonky.
0 -
Might not be for everyone.
- I repaint a new dark menu bar over top of the existing bar, anytime that rect is invalidated, there’s a slight flicker
- Right click menus in the editor widow are drawn white, there’s a flicker the first hit, subsequent menu calls are cached.
- Dynamic input sometimes invalidates the whole window, causing a repaint, so there’s a flicker
How to use, find your version inside the Zip file, drag the BRX onto the editor or use the appload command, select autoload as needed. I’ll try to refine it over time
edit: posted a better version
0 -
Modal Dialogs get a dark title bar.
old
new
0 -
Old
New
0 -
Ah, a good looking app
0 -
I also experimented with Qt stylesheets (QToolTip) to see whether the flyout tooltips could be restyled to improve readability in Dark Mode, but unfortunately that doesn't seem to affect the custom flyout tooltips used by BricsCAD.
So it looks like those tooltips are not standard Qt tooltips, or they are styled internally.
Thanks for taking the time to explain and for sharing your work. It was interesting to investigate.
0 -
The main frame and menu are not QT, I think to remain compatible with ObjectARX and palettes. I’ll probably post the code on GitHub once I’m done playing.
I’m actually taking inspiration from wxWidgets 3.3.X, where they implemented a nice dark mode. I suspect eventually Bricsys might use, I.e. instead of rewriting the drawing explorer from scratch.
BTW, here’s a sample BRX using wxWidgets with BRX. github.com/CEXT-Dan/WxArx
For the record, I’m not using wx here, just Win32 SubclassProc
Latest change, if the dialog does not have an ICON, attempt to add oneold
new
0 -
BTW, if you don’t use the menus, you can still hide it (MENUBAR 0). The flicking goes away, but you still get the dark menus and title bars
0 -
here's the source.
0
