Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
BricsCAD Sample Programs for C#
Hi,
Just started to explore the BricsCAD system and have been told by the support guys that there are some sample programs for C# but unfortunately, there is only 1 C# example I could find. Coming from EyeShot CAD engine (60 examples) this does not seem right. I am not looking in the right location or is there only 1 sample.
If there is only 1 example then where would I find or learn BricsCAD programming.
Please see the screenshot.
Thanks
  • Unable to identify your needs... Is starting with Lisp an option perhaps?
  • I am a software developer and am exploring my options to build my software on top of (trying Inventor and BSB) .
    I am familiar with C based syntax such as C/C++, C# but LISP i don't have a clue. but, then again there is only 1 lisp sample ints own folder...
  • Hi,
    The one sample has various sample commands, forms to illustrate using many parts of the API. Since your familiar with C++, you might also find something useful in the BRX SDK.
    Also, check out TheSwamp.org , there's probably thousands of samples
    Cheers :)
  • Thanks Daniel, I will have a look!
  • edited August 2019
    Most of BricsCad .net api equals AutoCAD Api.
    -> create an empty .net plugin for bricscad (add reference BRXMgd, TD_MGD - copylocal false)
    -> insert some of the x-thousands examples for AutoCAD (e.g. https://www.keanw.com/2011/01/combining-autocad-blocks-in-separate-files-into-a-single-dwg-using-net.html)
    -> replace Namespace and base classes from AutoCAD to bricscad (Intellisense of VS will help you)
    that's it
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
